I have a 94 SE when you turn the key off more than 5min the radio loses all the pre set stations I have check all the fuses none are blown. this only happens when turn the key off its like the radio loses all power
The #9 fuse is the backup power to the radio, make sure it has power on both sides with the key off. Use a test light or meter, not just look at the fuse.
Oops on my part, I was looking at the interstate fuse info instead of aspy/SE. It should be fuse #13 that supplies memory power, not #9.
And BTW, you do not need to start a new thread on the same problem, nor is it preferred. Just reply to the original.
Anti-Guru
FWIW... #13 fuse is located in in the relay box (behind the front edge of the left saddlebag) -- your clock should also be losing time and the CB losing station memory if #13 is failed.
