1 - 3 of 3 Posts
Yes, though as I recall, you'll need the wiring sub-harness that goes with it. The '94 I used to have was already upgraded when I purchased it, so I'm not positive about the wiring bit.
Senior Guru
This has been posted about many times. The later headlight will fit. The bulb connectors will fit. You only need the later connectors and bulb holders for the turn signals if you decide to fit the 98-2000 ones with the headlight.
1 - 3 of 3 Posts
