Looking to change those bulbs also to LED does anybody remember the bulb size number that is in there I believe there’s two ?
Are you talking about the red light below the license plate that lines up with the brake lights in each pannier?
If so, that originally was a reflector. There were two aftermarket replacements made. One is taillight only which should be 1156 bulbs. The other is brake and taillight which would be 1157.
If it functions as a running light only, it will be a 1156 bulb..
If it functions as a running light and a brake light, it will be a 1157 bulb.
Choose the bulb number according to how your light functions....!
What threw me off was the signal bulb in the rear was a 1073 and the running light brake light bulb the two filament bulb was a 2057
