1 - 3 of 3 Posts
What's the specs for replacement dash light bulbs. 3 small and 13 large
watts?
Can't seem to find them listed anywhere?
Sylvania has a list # 161 and a 168 for the 13 large bulbs
one is 2.7w and the other 4w?
Here's what I've got:
GL1500 dash lamps
Position Light 2x3.4w 6.8w
Turn Signal/Pos 2x8.0w 16.0w
Meter Illumination 4x3.4w 13.6w
LCD Illumination 2x3.0w 6.0w Indicator Lights 5x3.4w 17.0w
Indicator Lights 4x1.7w 6.8w
Use 194 for most of the 3.4w bulbs, 168 for the position and low fuel
24 (high output) or 74, 73 (low output) for indicator lights
the 1156 - 1157 leds will have to be right angle or they will not be visible.
Qty 4 - #194 (instrument lights)
Qty 3 - #194 (CruiseOn/CruiseSet/OD)
Qty 4 - #194 (HiBeam/Neutral/Reverse/SideStand)
Qty 2 - #168 (Low Fuel Warning/Low Oil Pressure)
Qty 2 - #24 (left turn signal/right turn signal)
Qty 1 - #24 (LCD Display (top portion)
Qty 1 - Either #24 or #194 (Temp/Fuel guages)
{http://archive.gwrra.org/wwwboard/motorcycle/7209. html,}
194 will do most of the instrument lights.
168 for the position and license plate lights these are the same
physical size as a 194 except brighter.
24 will fit the trunk lights if they are Honda line and the
remainder of the instrument lights
97 for tail light in fender
1156 turn
1157 tail & brake
Jack
Thanks Jack Joyce, I settled on 168's, appears the ones I took out were 158's, and went with 74's for the signals.
But I am going to keep your list:waving::waving::waving:
1 - 3 of 3 Posts
