1 - 3 of 3 Posts
Hello, had this Wing 6 days now, maybe 400 miles of riding it. When front brake is applied, it does not dive like 1100. Is this normal ? Also, the front suspension seems a little more firm than I'd like. 77,000 miles. Thanks for any feedback.
1987 GL1200 Interstate
The linked brakes may make the front system seem less responsive as the lever only engages one caliper. However, I would probably put new OEM brake pads all the way around and bleed the brakes real good.
The forks may also need attention/inspection.
It has anti-dive forks, if your 1100 wasn't an 83 it didn't. Does it have air valves on the fork caps? Might be too much pressure.
  • Like
Reactions: CrystalPistol
1 - 3 of 3 Posts
