when I turn my key tostart my bike the headlight does not automaticlly come on (sometimes that is). After it is started the light will eventually come on, say 3 to 4 minutes later. Any ideas where to start looking for the problem? Any help would be greatly appreciated.
jodell2
The reason mine did that was because I had a dirty starter button on the right handlebar. I took the button apart and cleaned it and the lights worked great again. Somew say just spray it with contact cleaner, but I figured that was a temproary fix. If you wanted to test the therory you could start there though.
Not the Guru on this for sure - I am sure someone will be along shortly with the know-how thou.
Pwhoever
You may also want to check the low beam relay. Mine went bad and would occasionally not come on as well.
