I was out riding over the last weekend and noticed that when I was at idle the rpm's were surging from 900 - 1200. This has never occurred before and it did it the whole day, whether the bike was cold or warm. Anyone have suggestions at what to look for?
Thanks,
Well it's sad to say....but you are gonna have to sell me the bike as it is nothin' but junk now:cheeky1::cheeky1::cheeky1::cheeky1:
Seriously....probably a vacuum leak. The 1500 gurus will be along shortly and shed some light in the problem.
try turning the idle screw up and down a few times this does cure it, its under the petrol flap knurled knob to the right
Monkey with a Football
I agree with both of these guys but given that it came on suddenly, I would favor Snorebaby's vacuum leak theory but the knob twisting is easy enough to try first.
Might have a problem with a leaky diaphragm in the automatic fuel shutoff.
Pwhoever
Mine just recently started doing that. I was starting to worry. It would only do that idle. It would usually do it at night when I had my lower driving lights on along with my 55 watt driving lights. I also had my Gerbings jacket liner and Union Ridge pants plugged in. (I am a wimp when it comes to cold temps) I noticed the Gerbing thermostat flashing on and off. I then realized that as the thermostat was flashing on and off, my idle was doing the same thing. I turned the thermostat off and a normal idle returned. I have a voltage gauge and still have plenty of juice coming off the alternator but the fluctuations from the heated gear causes momentary higher idle.
You didn't happen to forget and leave the choke on ???????
