1 - 11 of 11 Posts
Hello folks, this bike is kinda new to me, well i've had it for 3 years but only used it around town until 6 months ago since i got her new tires and front fork tubes.
I've installed a new fuel filter and air filter and ran a can of seafoam.
When going past 85mph it wont keep that speed for longer than a minute or two and it will start stuttering and slowing down, i've already tried opening the gas cap but it wont cure it.
below that speed it runs really nice, strong and smooth i can cruise at the max cruise control speed with no problems (around 80mph)
Any idea what can it be? Where should i start??
Sure sounds like lack of enough fuel. May be the vacuum petcock has a small leak and with the vacuum low at high speed it just can't stay open.
Sounds very typical of a failing fuel pump that only pumps enough fuel for 84 MPH. :)
this is my suggestion and exactly what I had to do to fix the same problem on my '98SE a few years back.
with my bike, it was a bit worse... it would run for about 2 miles and suddenly 25 mph was the best it could do. stop and let it idle and it would make another mile at 35ish....
I was 11 miles from home when it suddenly decided to go into fail mode like this..... and I replaced it with the NAPA/Carter fuel pump.
https://www.goldwingfacts.com/forums/10-reference-faq-forum/388784-gl1500-fuel-pump-replacement-napa-p72190-pump-easy-fix.html#post1613038
My '98 suffered that too at 85mph and it was a vacuum leak to the petcock.
It couldn't be the Flux Capacitor - He never made it to 88 MPH.... :ROFL:
Try Bypassing the Fuel Petcock... If the speed problem goes away, then you've found the culprit.
Discussion Starter #11
ill bypass the petcock and see if it fixes the problem, where is the other end of the vacum line?
1 - 11 of 11 Posts
