I picked up a qt of MMO today at Wal Mart, and I was wondering how long is it safe to leave in the fuel? What about the Qt in the engine to do a flush when i do my oil change in March, 09? Is sit safe to run 50 mile intervals, up to 200-300 miles? Or do you have to run the Wing Continusly 2-300 miles, at a low speed, then change the oil and fiter?
Thanks,
Nightrider1
Monkey with a Football
Didn't have directions on the container????
Look it up on their website, if not.
mostly the old-wingers run it about 100-200 miles before an oil change, on occasion, to help clean up the sludge n the engine.... a few onces in the gas does help with winter prep, and I have noticed, when I end up with some "pining" gas, helps with that
Rudy,
It did, but not the specifics here. I hve looked through so many, and many conflict.
Thanks,
Nightrider1
02 GL1800 w/Auto Pilot
As a fuel additive, use it for ever and ever as a valve guide lubricant. Also has some mild cleaning properties that are useful.
In the oil, you can do the same, but it is recommended to flush it out with a regular oil change as it is thinner than the regular oil.
I bought a diesel Suburban several years ago. The engine was missing terribly. It had sat for years without being started.
I poured in a gallon of MMO to 30 gallons of diesel fuel. Also poured in about 3 quarts to the engine oil. My diesel mechanic told me to drive it to Payson, AZ and back "like I stole it" which is 120 miles one way.
He was right. when I left home top speed was 40 mph with no willingness to get up and go.
By the time I started back home from Payson, it was running pretty good. By the time I was on the down wind stretch for the last 20 miles it was nudging 100 mph and had almost normal horsepower for the engine that it was.
I changed the engine oil and filthy isn't a good enough description for what came out. I dumped in another gallon of MMO in the fuel tank and filled it up.
Did the trick. It is good stuff.
