1 - 3 of 3 Posts
· Registered
Hello,
on my 2001 GL1800A goldwing, I pulled the front and rear wheels off and had the tire changes. Brake pads seems okay. Taking off the wheels and putty them back on went smoothly. (I did not even think anything about the ABS braking system.) Brakes seems to work fine. (I do hear the high pitch sound of the abs brakes - at least I think i do.) But the ABS lights stays on after going greater that 10mph. Using the technical manual procedure to determine the error code, it seems to blink just once : stays on for a couple of seconds and goes off for a couple seconds - and repeats. I tried wiping the speed sensor on the front right side but that did not help.
Any suggestions would be appreciated
Thank you !
1 - 3 of 3 Posts
