ABS WARNING LIGHT ON
1293 Views 2 Replies 2 Participants Last post by  John and chris
Hi All, hit a crevasse in the road coming back from scotland, ABS warning light started to flash. now stays on, front wheel took most of the impact. Think it may be the front wheel ABS sensor, any advice would be appreciated. Is It A honda part only? thanks John & Chris. GL1800A 02
1 - 3 of 3 Posts
Fraid its Mother Honda for that part. Check first for a mud or dirt trapped in the grooves of the ABS plate because that can cause the ABS light to stay on.
thanks ronnie stripped it down found that caliper had come loose. sensor catching groves and worn. found a pan sensor may be the same £20 from scrapyard
1 - 3 of 3 Posts
