1 - 3 of 3 Posts
I think I was wrong once!
I have a 1986 GL1200 Aspincade and I picked up a used audio mute button & radio tuner switch from e-bay for my bike. It is now added to the rear grab bare for the passenger to control, (I'll call it rider).
The factory installed mute / tuner switch on left handlebar (I'll call driver).
These switches wire harness have 4 wires in it, I did not fine this wire loom in my manual but the color codes look like...
Dark Blue with Black stripe I'll call 1
White with Blue stripe I'll call 2
Yellow with Red stripe I'll call 3
Red with Black stripe I'll call 4
Remove the driver switch and wire from bike.
Near the plug end strip back a 1/4 of insulation from wire 3 and 4.
Cut wire 2 and strip back 1/4 from each end.
Cut the plug off the end of what will be your new rider switch
Rider switch wire is to short you will need to add about 3 foot of wire so it will reach the rear grab bar.
Tuner
Solder yellow #3 rider wire to yellow #3 driver wire.
Solder red #4 rider to red #4 driver wire.
At this time the tuner will work on both rider and driver control switch.
If you add the mute button wires 1 & 2 the same way you will need both mute buttons pressed down for the audio to mute.
Mute
Leave driver White #2 wire untouched.
Solder rider Blue #1 wire to driver switch side Blue #1 wire
Solder rider white #2 wire to driver plug side of Blue #1 wire
Both mute buttons will work separately wired like this.
That’s it, reinstall driver switch and install rider switch (I drilled a small hole in a small hose clamp and mounted the switch to the hose clamp then mounted the hose clamp to rear grab bar.
See drawing....
FitzA1
The unit is nothing more than a factory switch identical to the one mounted on left handlebar. No link becasue it was just an item I found for sale on e-bay, any used, working, mute tuner switch that is for your left handlebar control will work.
1 - 3 of 3 Posts
