I did pull the spring out on one side, then found out how to do it here in this forum. Pulled the front wheel, fender then removed the 4 allen head bolts (2 each side) that are located just behind the headlight assy. on the lower front fork brace. I then removed the false tank, handle bars and used a rubber tie hooked to the frame under the seat to support the handle bar on each side(first checking to make sure the fluid was not leaking out of storage container on each side)remove 2 allen head bolts and the air line which is conected to the top fork brace. Now this is the area I missed up, there was a sensor line that ran down the center of the frame where the steering bearings go, I have not gotten back to this yet but I am pretty sure the connector can can be disconnected from the wiring harness where these wires come off of the main wiring harness and then be pulled up through the frame. I on the other hand did not disconnect them and was lucky that the main 4 wire connector disconnected itself but there were two more wires that I broke pulling the ign. switch out, not all bikes have this sensor but mine did.Once the allen head bolts and air line has been removed,the forks will slid right down without removing the end caps on the forks,let it slide down a few inches and you will see a retaining circlip that is very week and can be removed by hand,once removed the whole fork will just slide out. Once removed there is a bolt that is recessed where the axle bolt rest, I was lucky and they both were able to be removed by an allen wrench,although some have had to use an air wrench due to the spring turning inside and the air wrench with allen head tool spun it fast enough to loosen it up.Once the bolt is removed drain the shock oil into a container while pumping the shock up and down forcing most of the fluid out. Then remove the dust seal and right under that is a snap ring,my snap ring pliers were worn and did not work even after I bent them to perfectly fit,I ended up using a small pair of craftsman needle nose pliers that were made with a 90 degree angle and a couple of small flat tip screw drivers, as I squeezed the snap ring with one hand I put the screw driver behind the snap ring, then I stuck the other screw driver in behind the other one and worked it around like changing a tire, once about a 1/4 ways around I took the needle nose pliers and just gave the snap ring a little pull and it came out very easy.Then grab the upper part of the shock and hold onto the lower part and slid it like a pull hammer until the seal comes out.Clean up blow it out,inspect bushings if too much copper is showing replace bushing,coat all parts with fluid and put it back together,make sure the seal is installed correctly,you can put the old seal on top of the new one to help install it so that the new seal is not damaged,if you have about a 2 inch x 16 inch pvc pipe you can use that to drive the seal into place,your pvc pipe ,must fit real good around the outer edge of the seal as it does take a good amount of pressure with (rubber) hammer to get this seal to seat as the snap ring must snap back into place, once I thought it was seated good enough I put the snap ring in and used the same pvc pipe to drive the snap ring into place,look closely to make sure this snap ring is fully seated.I then put the bottom allen head bolt back in with a small amount of rtv around the threads up near the head of the bolt, remove the drain plug and use the drain plug hole to refill fork with oil with the required amount for your bike. Good luck
