when do valves need to be adjusted.she has about 71000 miles.dont know if po had ever done it.dose not make any noise just wondering if i should adjust them while the weather is a little cold.and will have a little time to do it???and what do the valves set at.do you set them hot or cold??( thanks ahead of time ):baffled::baffled:
Download the manual on the web.
As Bagmaster said, there is everything in the manual, but I just want toaccent that the valves should be adjusted with the engine cold. Don't overlookthat, it's important.
Alex
On the '82 'Wing the intakes are set at .004" and exhaust at .005". I go for a light drag on the feeler gauge. If you are going to check carb sync on the 1000 and 1100s check the valve lash first, it can affect carb sync.
As the miles rack-up they hardly need much adjustment. It seems the valve seats settle into the head and unless some damage or overheating occurs they rarely need ongoing adjustment.
I always used .004" intake and .005" exhaust specs for my '81. I still check every 10-20k miles but I haven't loosened the locknuts in over 5 years. Just don't need much adjustment on well broken-in engine.
Valves adj should be checked every 15k miles or everytime you replace your spark plugs (which ever comes first, it is part of the "tune-up")
