okay,
on vacuum operated valve,
hook a piece of hose to it, and suck on the hose.
does it hold vacuum, or bleed down on you.
the hose that was on it, should have vacuum while the starter is turn the engine over, is that present?
the fuel pump test per the manual, is a 3 ft high container and the pump should pump in approx 1 pint of fuel in 1 minute.... sort of going by memory now.
Courtesy of Dave Boher:
1988 – 2000 GL1500 Gold Wing’s
Fuel System Circuitry
1. The Engine Control Module (ECM) pin # 21 provides voltage/power for the fuel pump. Reference: Fuel System Circuit Diagram “Fuel Pump Control Output” in the Honda service manual.
2. A black/blue wire goes from the ECM pin # 21 to a C 178 (4-pin white) connector located on top of the fuel tank.
Note: For the 1988 – 1989, the Fuel Pump Relay provides power to the fuel pump.
Located on the frame behind the right saddlebag.
3. A black/blue wire goes from the C 178 (4-pin white) connector to the In-Line Capacitor D located on top of the fuel tank.
4. A light blue wire goes from the In-Line Capacitor D back to the C 178 (4-pin white) connector located on top of the fuel tank.
5. A light blue wire goes from the C 178 (4-pin white) connector to a C 184 (1-pin black) connector located on top of the fuel tank.
6. A blue wire goes (from the terminal where the C 184 connector is plugged) directly to the fuel pump.
The Fuel System Circuit Diagrams and connectors can be referenced in the Honda Service Manuals.
Page 4-5 in the Gold Wing GL1500 Service Manual.
Page 3-2 in the Gold Wing GL1500 Electrical Troubleshooting Manual (ETM).
Page 12-11 (photo 67) in the Gold Wing GL1500 Electrical Troubleshooting Manual
(ETM). (In the 1996 Manual)
Page 12-9 (photo 59) in the Gold Wing GL1500 Electrical Troubleshooting Manual
(ETM). (In the 1999 Manual)
Check for voltage/power at the C178 connector.
Check for voltage/power at the In-Line Capacitor D.
Check for voltage/power at the C184 connector.
Note: The In-Line Capacitor D is installed on all 1993 – 2000 SE models, other models
when adding a Hondaline CB radio.
If that Capacitor D is bad, the fuel pump will not have input voltage.
