1 - 11 of 11 Posts
I want to put louder horns on My 85 Aspy With a relay. Having trouble finding the wire from the horn button any one know what colour it is[ they are]?Thanks.
Hi TJ859
use the wires connected to you exisiting horn for the relay, then take a new supply, for the new horns
welsh winger
G
How is that for service and welsh winger is not even a "Guru" :jumper:Well done welsh winger.
:coollep: :18red: :coollep:
Success!!! welsh winger insataled a pair of bosh mini fanfair horns from 99 dodge ram pickup man are they loud just what I was looking for.Thanks again.
Glad you sorted it TJ859.
welsh winger
Most, if not all of the high out-put after market/auto-motive horns can draw a lot more current than you may want the stock wiring exposed to. A seperate relay and heavier supply wire IS the better way to go... :action: :gunhead: :action:
Discussion Starter · #11 ·
BigAl definately install a relay, use a fuse holder at the batteryfrom thebattery to the relay You must protect the horn button from what I've been told the 1200s do not have a horn relaysomeone on this site can help you figure out the wiring if you need help.
1 - 11 of 11 Posts
