Best looking member
Looking to keep a spare relay or two on the bike just in case.
rt66john wrote:
I put one of these in my 1500 a couple of years ago when the low beam relay quit. I found it at AutoZone, in the section with the fog/driving lights. I just cut the mounting tab off and it fit pretty well.
http://www.pilotautomotive.com/Product.aspx?ProductID=27342
> Ditto, note that even though these are 30amp, you can however use them for Any of the locations relay box (eg Ok to replace 10 or 20amp relay with 30amp)
Pwhoever
Besides the PL-RY1, you can also use the NV-RY1. They are basically the same and have the same pin configuration. The PL-RY2 will not work as it has a different pin configuration....
Best looking member
Thanks guys, how much would you pay for these relays in the US ?
I get my relays at the local U-Pull-It at about a buck a piece, I found if I'm buying a larger piece sometimes they are free. You can find all types those with mounting tabs and those that can be mounted in a rack. I have about a dozen laying around here some place.
