Air cleaner change on 01 gl 1800
386 Views 4 Replies 4 Participants Last post by  T
Watched vidio did step by step didnt seem to be any problem until I reinstalled air box cover then all wires on both boxes that are on the left now i am ready to put on fuel tank shelter but I notice a white plug on the right side that doesn't seem to go any where.
So I thought I must have droped other end down beside air box. Took it all apart. Nothing to find. reinstalled all to the point of shelter and came to ask the experts. The plug comes off the grey plug loom that goes to the left side of main shelter radio controls and goes across to the 4 way plug in the large black boot with a fuse holder in it.
I cant rember unplugging this am i on crack or???? :praying:
It is an extra connector for a CB radio I believe.
Sounds like a connector for either the CB radio or a CB noise filter.
If you post a picture it will make it easier for us to ID.
Like the others already mentioned, this is most likely the CB connection. This white plug on right side is not plugged in to anything unless you have a CB installed. No issues, button her up and go for a test ride!
thanks all
:claps::claps::claps:
