Hello y'all ,
I'm looking for a little guidance. I suddenly realized my air compressor is not working when I hit the switch. It will not increase pressure nor will it decrease pressure.I do not hear any solenoids click when I hit the rocker switch. The pressure shows on the dash when I hit the "pressure check" button.
Question. Is this more of the "switch" problem ora "compressor" problem or possibly wiring problem. I checked the fuse and swapped the compressor relay with no luck. I recently changed out the rear tire so I don't know if I did anything removing the wheel.
Hopefully somebody can give me some direction here. Any help would be appreciated. Thanks in advance,
Yak
Check the air pump fuse #6 and the air pump relay #5.
OH, excuse me I just re-read your post and see you did check those.
Back in a few with more info, maybe.
Have you checked with the key in the park position if the compressor runs when you push the outlet switch?
You are hitting the p check buttonat the same time as other buttons arn't you?
OMG........It's been so long since I've used the compressor I forgot to push the pressure switch when running the compressor. Duh !
Thanks for the replies guys.......
