Is there a reason why the compressor only works in the AC switch position? I wouldhave thought it better to use it with the engine running to prevent the battery running down.
I think the thought process behind it is safety. They don't want people adjusting pressures while riding. I think I read that in the manual.
robbie1401 wrote:
Is there a reason why the compressor only works in the AC switch position? I wouldhave thought it better to use it with the engine running to preveynt the battery running down.
Are you referring to the Suspension adjustment or the outlet as in tire reair/fill?
I have wondered that about the outlet myself. My 1100 and the 1500 both have had to be in the park position on the key switch to use the outlet but not the Suspension. For Suspension adjustments, it works while the bike is running or not with the switch in the on position, in neutrel.
Yes, I,m referring to the outlet.You can sort out a flat tire, but end up with flat battery.
The trick is to run the compressor for a couple of minutes and then start the engine to charge the battery back up. Then use the compressor for another couple of minutes.
1985 GL1200 Limited Edition
Bingo, John nailed it!! At the bottom of the compressor display/control panel there's a warning not to run the compressor more than 5 minutes! If your battery is in good shape and you've been doing the monthly batteryinspections, you should be good to go! :blackstuff:
Very active member
boy, that sounds like a pain in the rump. i may be kinda glad the po took out my compressor now. wait, nope, still wish i had it.
