THIS FORUM IS TRULY THE FONT OF ALL KNOWLEDGE REGARDING GOLDWINGS SO I HOPE THAT SOMEONE CAN SHED SOME LIGHT ON MY PARTICULAR PROBLEM I HAVE AN 86 1200 ASP AND I HAVE LITTLE OR NO RESISTANCE FROM MY REAR BRAKE PEDAL UNLESS I PUMP IT FIVE OR SIX TIMES AND THEN THE REAR CALIPER WILL LOCK SOLID AND WILL ONLY RELEASE IF I LEAVE IT FOR A WHILE OR RELEASE THE PRESSURE AT THE BLEED NIPPLE BOTH FRONT CALIPERS SEEM TO BE OPERATING FINE I HAVE CHANGED THE PADS, CLEANED THE PISTONS, REPLACED THE SEALS, GREASED THE BUSHINGS AND TRIED FOR HOURS TO BLEED THE SYSTEM BUT ALL TO NO AVAIL I DID TRY RIDING THE BIKE USING JUST THE FRONT BRAKE BUT AFTER A MILE OR SO THE REAR AND FRONT RIGHT CALIPERS GRADUALLY LOCKED SOLID AND COULD ONLY BE RELEASED BY ALLOWING TO COOL OR RELEASING PRESSURE FROM THE BLEED NIPPLE WHICH SQUIRTED OUT LIKE A WATER PISTOL AND WAS VERY HOT :shock: I DID TRY TO INVESTIGATE THE MASTER CYLINDER BUT TO MY HORROR FOUND BOTH NUTS ON THE BRAKE PIPES ROUNDED OFF , SO I NEED TO KNOW DO I PURSUE THE TRAPPED AIR ROUTE? OR THE MASTER CYLINDER? AS THE LATTER IS NOW A JOB I WOULD LIKE TO AVOID.
I SHALL SIT BACK--------------- RELAX-------------- AND AWAIT YOUR PEARLS OF WISDOM!
TAS.
TAS.
