I cannot get the pressure in my shock to increase, readout stays at same pressure. I can hear the pump running and I can get air to come out the hose on outlet. Bike on centerstand, display reads 8 lbs. Any ideas?
Just another ORF!
Are you pushing both buttons, with the bike running and in neutral? .... if so, I'd be checking the air hose connection at the top of the right shock next.
I had the same prob with mine and the valve on the tire chuck wouldn't seal. I'd hold my finger over the end while pushing the button and it was good to go, either that or replace the valve in the chuck :smiler:....Mike
Mrmikey nailed it. The valve on the end of the auxiliary hose wasn't sealing, unscrewed the hose from the outlet and worked like a champ! Thanks!
