Banned
The rear shocks on my 81 gl 1100 stay pumped up only if I fill them all the way hard , if I only put 35 or 40 lbs in they will leak down some times in only a couple of hours or even less . I don.t get it ?? I do prefer the harder fill but just wonder why they do this??
Senior Guru
hi picasso sounds like the seal in the shock when you fill to the top the pressure forces the seal tighter on the shaft
Banned
Thats just what I was most fearing,,,,,I just did put new saddlebag bars and stuff on ,,,now to take it all loose to replace the dang shocks!!!! Dang!!!
Well maybe I'll wait till I have too!
could be a connector loosened , little rubber seal inside broken or worn, who know's squires could have chewed the hoses. many possible thing's
Senior Guru
picasso if you mix up a little water and washing liquid in a spray bottle can you get to the shock and see were the bubbles come from
Banned
No obvious damage except for a broken boot rubber . I will check for a hose leak but the seal makes more sense as it does stay pumped if totally pumped up.
Thanks everyone.
I would think if it was a seal leak, you would see some fluid leaking somewhere.my fronts used to leak down in a couple of hours.When I changed the tube fluid, I greased up the orings and made them good and snug the leak stopped.
The rear air shocks are rebuildable, the seals can be bought at www.servicehonda.com and very reasonable too. I rebuilt a set last spring and it was easy and cheap....
cheers,
Kevo
