air suspension display/1985 1200 anniversary limited edition
852 Views 3 Replies 4 Participants Last post by  daveinozbikes
:(:shock::? just got this bike and thanx for being there for us fellas and gals. bike will read one of two things either all EEEEEE's on both display lines or all-----------'s on both lines then lo and behold the other day numbers came up and was calibrated to appropriate settings. help me because w/ my petite wife(LOL) I bottom out when I hit some bumps. any ideas??????????
I think that means you have a leak. It's an error code from the pump.
A leak, or dirty/loose electrical connections.
You"ll need a wiring plan to check the connectors. While your doing that check and clean every connector you can find. Buy some electrical switch cleaner and lubricant. Had one of these beautiful machines for nine years. Had to learn electronics...easy....:)
