That was probably me..
By using a special sparkpug adapter that can be connected to compressed air (available from autosupply or sears, in a compression testingkit), pressure can be applied to a cylinder when the valves are closed (at Top dead center). Usually this test is used to look for leak down past the rings or through the closed valves, but in the case I mentioned, I also used it to find what cylinder(s) were leaking gases back into the coolant.. When I pressurized the offending cylinder, air bubbled up through the coolant.
