Just curious, I have a Scorpio I900 system and have it under the seat...mutes the sound by about 40% being there. Where did you locate yours? Pictures?
Don't have that system. I do want to put on a Lo-Jack system on board though.:action:
No ideas how to help since I don't know what it is you have other than being an alarm system!
hhmm...had not thought of that....but would have to splice wires...they would not run from there to the turn signal connector under the seat.:(:(
Senior Guru
Under the pocket and up near the headlight is the best place for it. It isn't a big job to run the extra wiring up from the TS block.
Discussion Starter #10
Well apparently I had everything right. I just needed to figure out the sequence of when the unit arms itself with the switch and when i do it manually. Everything works great! Thanks for the help.
