Hi All,
I got my forks back from my local Honda dealer (RR seals and Progressive spring installation) and I'm in the process of re-installation. I had also removed the steering stem to replace the bearings and races. Stem is re-installed.
I'm having a little problem getting the tire, forks, and handlebars aligned right. Is there a trick to do this? Just when I think its right, I look and the handlebars are straight ahead, but the tire is pointing alittle to the left, or vice versa. Nothing is tightened down (fork clamps, axle bolt, steering stem locknut) so I have some play to work with. Any help or suggestions welcome.
Bike is a 1995 GL1500i
TIA
Hi All,
TIA
