1 - 2 of 2 Posts
03 1800 with 17k miles. all marker/turn signal light up in front ok. NO tail lights. Have a rear spoiler with light that is a brake only light. when i hit the brakes (either) both turn signals on the dash light up. ONLY the spoiler light comes on (bright and shouldn't at all) and rear turn signals illuminate faintly. disconnected spoiler light to no avail. also, the cruise won't engage even though red cruise on light is on. Figured it was a BAD GROUND.
MY RESULTS
checked for loose or frayed wires in the rear under the trunk then harness under the seat and found the connector under the passenger seat, the GREEN WIRE (Which is a GROUND) wasn't making proper contact in the connector, so I crimped the connector tighter and jumped a wire from the male side to the female side.
GOT LIGHTS
There has been issues with that same connector "ground wire" on GL1500's....!
It is busy, provides "ground" for all lights on the rear of the bike....!!
1 - 2 of 2 Posts
