This is a night time bad situation. Luckily my headlight is not effected. This flickering is random does not seem to be effected when hitting bumps. Almost all lights including my side car lights go out for 30-40 sec. then come back on. When they do come back on the dash lights up as if I'm turning the key on.
I'll have full running lights for about 5 min. then with out warning...blip.. all running lights, dash lights, side car lights go out.
What is not effected: Motorcycle head light, head light beam indicator, engine temp, gas gauge lights, and brake lights
Is there a common fuse that all these lights run through?
Thank you.
Other side of the pond
Does it change if you play with the ignition switch?
mr irrelevant
My thought would be ignition switch also. But dash lights and tail lights are powered from relay #3. Swap it out with air compressor relay and rule that out...Am also sure others will be along with a lot more experience than me...Good Luck...
Thanks guys. I've tried wiggling the ignition switch but this appears to have no effect. I'll try relay 3.
