Ok brethern, heres a question regarding a conversation I had,couple wks. ago with a former GW owner while at a biker event.
Anyhow,he said he had once owned a ,think it was a 89 or 92 & how it was a great ride,but, sometimes the alternator brush springs will corrode,causing the brushes to loose tension on the armature & cause it to stop charging:(& fail w/o warning!
He said it was easy enough to chg,by replacing the brushes using stainless steel springs as replacements.
Now,,is this a project I should put on my "to do" list this winter?? or can it wait till later.I have a 1990 Aspy w/ 23 thou.on it :bow:
Have never seen corroded springs but I have seen numerous instances where graphite worn off from the brushes has built up in the brush housing causing the brush to stick and thereby not charge properly... Don't think I would bother with the SS springs if available...
Les
The alt. is positioned out of the way of rain etc.
An early model alt. is a good one and worth a rebuild.
See the tech. sechion re; this step by step .
Did my 88 for $150.00
First I check and see what the voiltage output is.. 13.85 14.8 around these number are good..
If it's low 12.5 than I'd pick up a set of brushes.. $7.45 a set with new springs at the honda shop..
Easy to install be sure and use air to blowout the insides good................
Perhaps the comuntator is grimey between the armeture grooves.(carbon dust) Sounds like heat is annealing the springs. Dirty and partially bridged grooves arc = heat. Just a thought. :?jimsjinx
Thanks group for all the advice,this site takes the anxieties out of maintaining & preservation of our beloved GW's :applause:
Banned
When my alt first went out, I was assuming it wasn never rebuilt or was done many years before I did it. The back side of the brushes and basically in the interior components were relativley clean....and these brushes were REALLY worn down. I bought a set from Cyclemax (I don't think the where I bought it was important as much as my assumption they were aftermarket) A year later the thing stopped charging again. I tore it apart again and it was filled with carbon dust holding the springs back. I heard other bad issues about the Hitachis so I bought one off Ken hemmings. The point is, are the aftermarket springs were buying for re-builds softer and more prone to quicker wear and this powder build-up? It would seem so from what I experienced.
