-- as above..
, and the OEM harness has a 55A dogbone fuse between the battery and alternator output (which should be sized appropriately for the alternator's output if you hope to charge your battery at the alternator's rated output).
Personally, I recommend changing the harness from the alternator to the battery as you're thinking. Use heavier gauge wire and change the Dogbone fuse for something more easily replaced (and less fragile).
The PAL long leg fuse series ( "FLB" ) can be retro-fitted into the dogbone's old holder... (FWIW, the 60A fuse will hold 60A all day, & blows at 120A and is a good choice for Compufire installs, IMHO). JCASE ( "FMX" ) is another option, but I find the PAL ( "FLB" ) fuses easier to find in the correct size.
The output from the alternator does runs through that dogbone for the battery, AND also runs directly to the OEM fuse-panel - changing this fusebox feed wire is kinda a booger as it's spliced to the alternator-to-dogbone wire and crimped/bundled in with the rest of the harness running to the fusebox.
Upgrading the alt-to-battery (including some sort of appropriate fuse) wire is a good thing, then you can add load at the battery side of the circuit and leave the OEM load (and alt-to-fusebox) wiring unmolested.
A couple of thoughts that came to mind:
* To increase the current handling of the Alt-to-Battery harness, you can simply ADD an additional wires in parallel with the factory wires. I used 8-AWG here though 10 or 12 would prolly be more than adequate (ensure that the wire you choose is good for vibration, heat, and oil) This'll save you from having to deal with cutting the OEM Alternator output harness to replace the alt-to-dogbone wire length.
pwhoever presents the PAL / FLB fuse approach quite well inTHIS
LINKED THREAD .
* A red 50A PAL fues will hold at 50 and blow at 100 and the 70A in pwhoever's post is a brown one (blows at 140A)... Take a look at the "fusible Link" section of your local autoparts store to see what can be commonly found in your area
