I had whined before about reduced alternator output: 21 amps in February dropping to 15 amps in July and 95-100 temps. I ordered and installed the EC wiring harness, looking for an easy fix. Before connecting to the harness I checked stator wire to wire resistance at 0.6 ohms, the same as Feb. The stator wire to ground resistance shows 0.6 ohms (shorted from winding common connection, inside stator to ground) on all wires, compared to Feb's 20 Megohms (open). The stator wire to wire no load voltage is about the same at 60 VAC at 2500 rpm.
Being poor, Ineed a cheap fix. Is there a way I could burn off the short with a high current?
How long do you guess it would take a first timer to pull engne, install stator, replace engine? Who has wrenched on his own bikes for 20 years (which isn't a lot).
How much labor at $60/hour for a decent Wing specialist mechanic to uninstall the engine, replace the stator and re-install the engine, ? Do you see the failure repeating itself?
A Canadian guy on EBay is advertising new stators with 20% greater output for $200. I've seen rebuilts for $150. I haven't had the courage to see what big Red wants.
Thanks for sharing experience and sugggestions,
Bob Rust Albuquerque :baffled:
which year wing do you have?
pulling the engine (at least on 1000 and 1200 is mostly time consuming and makes you wish you had smaller hands and fingers. The clymer and haynes manuals have good step by step instructions. Once the engine is out, the stator is easy to reach.
btw where are you from?
Hi Bob,
I'm from Rio Rancho, i just had the same problem a few months ago. I can tell you that we are very much in the same boat (wrenching on our own bikes), but with time restraints and such i found it easier to get the work done for me.
I took my goldwing (84 GL1200) to R&S Honda on wyoming, they are a great bunch of people. I gotta tell ya that since I knew they were going to have to drop the engine i had them do alot more, shift shaft seal, valve cover gaskets, the stator, etc,.
The total for all they did was $2100.00, but it was worth it, had the famous 3 yellow wiring and starter relay wiring done. The pigwing runs great and i just got back from a great ride to california. Hope eveything works out for ya, get in touch if ya need any help, nice to see someone on here from NM.
Oh and by the way the stator they replaced came with a life time warrenty that includes labor.
Take care and be safe
Jim
· Postpubescent member
I wouldn't try to zap the winding, once they're gone they're gone. There are cheaper places to find stators:
Rick's: http://www.ricksmotorsportelectrics.com/index.php
Electrex in Britain: http://www.electrexworld.co.uk/
Electrex USA: http://www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4001827
There's another site that offers heavy duty stators but I can't seem to find it right now.
Bob, how are you measuring the amps output?
Are you measuring the ohms to ground with the 3 yellow wire connector unplugged? (it must be to get an accurate reading).
With 60 volts AC from wire to wire that sounds pretty darn good for a shorted stator.
Try letting the oil drain off the stator all night then re-measuring the resistance to ground. Remember to keep your sweaty fingers of the metal ohmmeter probes as that will lower the resistance.
It's really hard to measure the amps output as it will only supply enough to keep up with bike & battery's demand, the rest goes to ground in the regulator before you can measure it. (maybe add a couple of extra headlights across the battery then measure what is coming out of the regulator as it enters the red/white wire supplying the bike/battery).
Twisty
