It depends on what you are trying to install. Is only the mast broken off, or do you have the entire piece including the knurled bottom?
If you have the part #11, there is a locking nut #13 that must be loosened first. The antenna will the unscrew.
If it's' just the mast itself broken, I believe they are press fitted into the bottom piece.
