Hi there, I've just received the timing light made by "Rite Autotronics Corporation (RAC)" which I purchased on Ebay for $9.50. It's an old item, I guess made during '60-es, but never used. It has three cables as usual, two goes to the battery and the third "trigger" one goes to the spark plug cable. However, on that third cable there is no built in spark plug adapter which I expected to find there (to be inserted between the plug's cap and the plug), but only a highly insulated alligator clip. In the user manual it says I should add the spark plug adapter between the plug and the cap and then attach that clip "on the middle of the adapter".
However, that adapter is not included, so I was wondering is it actually just a piece of metal to provide the access for the third cable's clip to attach (without any resistors, capacitors or other electronic elements) as in that case I could easily improvise it or find some other place on the cable to attach the cable directly to it, or that adapter has some more roles besides providing access, like to reduce the high voltage or something? So, basically, is the "trigger" cable attached directly to the high voltage of spark plug or there is some advice in that adapter to reduce that voltage?
I sent the picture of unit, so if anyone ever had similar unit and knows how it works I would be thankful for any info!
Uploaded with ImageShack.us
