1 - 3 of 3 Posts
I am wanting to get a Factory Honda CB for my 1984 Aspy. Do I just need the actual CB unit itself or do I need other components to make it work? If I remove the cover where the CB mounts, there are some DIN connectors and power wires laying there that look like they would go to the CB.
It depends a lot on what original equipment your bike came with. On my SEi I had the radio/tape deck and intercom. What I needed was the cb and the multichanger box. The best thing to do is get the oem Honda manual and compare what you have to what the book shows. Or check this site out;
http://www.msgroup.org/goldwing/type3cb.html
I hope you're good at following schematics because it's a bit complex but doable if you take your time. On my bikethe wire identifiers(tape colors and plug colors)matched what was in the book. The hardest part is getting the left pocket back in with all the wiring and equipment that's in there after you're done!
1 - 3 of 3 Posts
