1982 GL 1100
The right muffler fell off, so I need another set. I like the idea of using clamp on pipes, but do I need the crossover connecting the two sides? I thought that this was needed to balance the system.
cheers,
chriso
cross over pipe---no you can get by with out it. a lot of guys have installed Harley mufflertake offs and don't use a cross over pipe with no ill effects.
My aftermarket pipes had a crossover. I cut it off and welded the holes shut. Can't tell any diffeence. Makes removing a single muffler so easy.
Bobby
My 82 has Harley mufflers on it no cross over pipe
The only issue that I could see with that is if there were a difference in the mufflers internally causing more backpressure in one and not the other. But that's only a very very small chance of happening so I say go for it. It won't hurt. :)
Hi Chriso,
I put clamp on mufflers on my gal as well. I was going to do a crossover but decided it was not worth the effort. I certainly don't regret it at all. I have had Zero issues.
Here is what I did....
http://www.goldwingfacts.com/forums/forum1/68562-1.html
Tim.
