1 - 3 of 3 Posts
Okay when I bought this thing (90 GL1500) the guy told me it needed a clutch because it would rattle like crazy. After driving it, the clutch seams to work fine. When you start in neutral it makes a bad rattle and also does it in first gear, sometimes second. When you get going it seams to go away.
I was playing around in the garage with the bike today (its raining outside), checking everything out. I started it up and listened for the rattle. It actually sounds like it is coming from the front of the motor, not the clutch area. I need to buy a service manual because I have no idea where anything is on this motor. Could it be a water pump? Alternator? Almost sounds like bearing going bad. The engine has so much plastic armour around it so I can't see the engine. I don't have my tools at this place yet so I can't take it apart. Any ideas?
It could be your timing belts or one of the timing belt pulleys. There are online manuals for your model but I dont have the link off hand. Just look for Gl1500 manual on this site and you should find the link. Good luck.
Download the manual on the web, they can be downloaded from lots of places.
1 - 3 of 3 Posts
