Another starter problem
657 Views 6 Replies 5 Participants Last post by  shadowace
When bike gets hot 1200 gl . Starter seems to get stuck.Would a rebuild (cleaning)
possibly fix this .I have asked this question earllier but wasent sure it was starter
but now i am 90 % percent sure it is the starter.I also went with seafoam dosent seem to change much. Also found a tread on here on how to rebuild starter but was for an 1100 is it the same .Or somewhat the same. THANKS IN ADVANCE
The 1100 and 1200 starter are pretty much the same, different but close. If it isn't working when hot then a rebuild will probably fix it. Seafoam is good stuff but it won't fix a starter.
Hey Shadowace...welcome!
Please check out the starter rebuild thread (it's a sticky up top) in the reference/FAQ forum. Betcha a good cleaning as per Tim's guide will fix your wing right up! (worked wonders on mine)
Dave
ooops...see you found the thread!
just cleaning up the brush area and changing out the brushes will make a huge improvement,did for me
what neoracer said... if you can, before taking it off.. order a new set of brushes. :)
is there a place u would recomend or just as good to order a set of brushes from dealer? What do u think their worth ballpark ? And thanks to everyone again.
