1 - 16 of 16 Posts
big PIA
I know this has been in the forums before. I remember everybody says not to use anything with silacates, but what are they? I have looked at diff. brands and none list any thing about silacates being or not being in them.
Sorry if spelling is off.
1987 GL1200 Interstate
Just use Honda brand coolant and you know you will be OK. The stuff you get at the car dealer is less costly.
Just go to WalMart and get the SuperTech Blue bottle.
It is silicate free and just as good as anyones antifreeze.
Mix it with 50% Distilled Water.
It is made by the same company that make Peak Antifreeze.
02 GL1800 w/Auto Pilot
Nearly all of the antifreeze products use the same manufacturers' ethylene glycol base, a major producer is Union Carbide. The different brands just add their own colors and additives to the ethylene glycol base.
I read that somewhere, several memory thoughts ago...
Bike...and Dennis is correct. If you want the Honda brand, the stuff at the Honda car dealer is the same, but costs less.
Silicates are sand. They sandpaper the inside of your water pump, causing premature failure.
That's what I do also. Done. Don't have to think about it.
Honda Guru
The basic rules on coolant is:
1. for motorcycles it HAS to be silica free
2. the coolant has to say that it's silica free… or it's not.
2008 Goldwing 1800
My Prestone Long Life states "silicate free".
Tex said it
big PIA
Discussion Starter · #11 ·
I looked at ingrediants and saw nothing that says silicates, thats why I am asking here, did not see any that that said silicate free eiether. And I was looking at WalMart. I know this question has gotten plenty old thru the years, but needs refreshed now and then.
I will check with Honda dealer as soon as I can, car dealer or bike dealer? or does it matter?
big PIA
Discussion Starter · #12 ·
Here is what I found about about Super Teck brand and silicate
No it doesn't, the coolant is made by Old World Industries which is Peak Brand, the formula for Super-Tech is basically an OAT which is good for American, Japanese or European vehicles. The MSDS can be found at http://msds.walmartstores.com/cache/339831.pdf which tells you the basic ingredients of the coolant, which is silicate free. Basically you could do a complete flush & fill with this stuff & last just as long & work just as good as the manufacturers recommended coolant. Not all coolants are equal though, some do contain silicates & other ingredients that some manufacturers do not recommend, check this matrix for more info http://www.eetcorp.com/antifreeze/Coolants_matrix.pdf
Read more: http://wiki.answers.com/Q/Does_Walmart's_'Super_Tech'_Coolant_contain_silicates#ixzz1ftKjFbFI
Honda bike dealers SELL ONLY 1 qt SIZE @ $7-$10 DEPENDING ON THE STEALER.(1 gal= $28-$40)
Honda CAR DEALER SELLS 1 Gal @$20
Both types are premixed, no diluting.
Junior Grue
Not all Honda dealers are created equal, here the car dealer is more expensive for the same product than the motorcycle dealer.
On a jug of antifreeze it's not that much but it does pay to compare as you should get to know your dealers from your stealers.
Disfunctional Nimatode
Yup.....prestone says it right on the jug. Works ok.:waving:
Also you can make antt-freeze by hiding her nightgown...
:cheesygrin:
1 - 16 of 16 Posts
