Antifreeze leak
708 Views 4 Replies 5 Participants Last post by  daz800
I have a Antifreeze leak not a hugh one but just a small drip on my 1500 where do I start to try and find where it is coming from.
Where under the engine does the coolant land on the ground, front, back or one side?
Remember that water runs downhill. Dripping from the lower left side of the radiator may be a leakon the upper right side.
your probably going to have to pull some covers off to see in there. i'd start with the lower cover cause that's where the pump is. check and see if it's leaking from the pump or higher up.:shock:
if you can get the system pressure tested.
This should show where the leak is from.
Or take the covers off and run the engine to see of you can find the leak.
Daz
