1 - 12 of 12 Posts
Any ideas what I can do to fix this? I can't find what is even under this cover anywhere online. I will take a picture when I get home and add to this thread but someone may know exactly what I am talking about without it. The leak only started when it got cold so I figure it is a gasket or a seal that is causing the issue.
More details to follow.
Blaine
Other side of the pond
Can you at least give us an idea of whereabouts on the side or the engine the chrome cover is Blaine?
Check coolant tubes between the carbs? The O rings leak there sometimes.
Here is a close up of the cover and I have outlined the spot where the leak seems to be coming from.
Thanks in advance.
Blaine
No coolant anywhere near the box in your picture. Probably running down from the coolant tube on top.
are you talking about the cover plate that has 4 small bolts holding it to the case ? if so , there is a gasket under that cover. (paper).
should be oil if anything leaking. coolant leak would most likely be from the tube on the right side. they are sealed with "O" ring on each end.
But there is no coolant in there, or at least shouldn't be. That covers the final driven gear on the output shaft.
I agree with Dave0430.. Check tubes on top.. may be running down
Or from the overflow tank. Or the tank's overflow tube. They start to get in sad shape at this age.
u r very close to the head gasket there, and there is anti-freeze there, u might pull valves cover and retorgue head bolts check book for pattern and bolt torgue. leak happens with onset of cold weather makes this suspect to me.
X2. Good thing to do no matter what the issue is with the OP's bike.
I had an 1100 that would leave a small puddle of coolant in cold weather. I re-torqued the head and found a few bolts with fairly low torque. A quick twist to the correct amount and it was fine for years; no more drips.
Bill
1 - 12 of 12 Posts
