I just finished restoring an '81 GL 1100 "parts bike" that I bought, which was intended for my other '81 GL1100 fixer upper. It only needed a carb rebuild and to replace some of the parts that were stripped off. So thats one off the endanger species list
I straddled the fixer upper before I bought it and both feet were firmly planted on the ground, (I'm 5'6" 160 lbs). The seat however was tattered and appeared reupholstered so I replaced it with a stock Honda Seat. My feet are still on the ground but my heels are now up. This one is still a work in progress.
The one that I just finished restoring has a Markland seat and when I straddle it I'm on my toes (on point Ballet) and with a 600 lb bike that is not a comfortable feeling. I assume that this is due to the Markland seat which I think is a little more plush than the stock seat.
Both bikes have no air in the shocks so now I'm concerned about how much higher it will be when I pressurize them. I'm also suspecting that the fixer upper that I can straddle might have weak springs and is perhaps lower to the ground for that reason.
What I'm trying to figure out is a way to safely lower the bike so I can straddle it with both feet firmly planted on the ground without having to dust off my platform shoes
I thought about sliding the front forks up the triple tree maybe about an inch. I know that maybe changing the seat or cutting some foam out could help but have any of you delt with this kind of problem? Any thoughts or suggestions would be appreciated. I'm not averse to doing some hard core mods.
