I'm having some serious issues figuring out my friends Piaggio Fly 150 (same as vespa LX150). When it's comin' down in the revs it pops and sputters, every once in a while you get a puff of black smoke with the sputters. It's also a b**** to start. Once it gets good and warm,if you pull up to a stop light the idle holds for about 2 seconds then dips a little low, then when you pull away from the light it sputters and hesitates then slowly accelerates. I'm killin' myself over this, I HATE VESPAS!!!!!:whip::whip::whip::whip:
So far, I've pulled and cleaned the carb and adjusted the float, pulled the plug (which was clean when I started checking this bike 3 months ago) and it was totally caked in carbon. That kind of supports what smelled like a rich mixture. So I ordered the damn specialty mixture tool from vespa and right now I have the mixture choked off totally lean and it's still sputtering and still running rich. I ran an entire bottle of sea foam through it (injecting it in the carb with a needle) and got tons of yummy smoke, but no change.
I know it ain't a wing, but I also know there's a lot of motorcycle mechs on this forum who have other experience. Please help me, I'm finding it harder and harder to restrain from taking it to the desert with some 12g deer slugs.
BTW, it's a 2009 with 4900 miles :shock:
