I ride a 2000 year model GL1500.
I put on kenda kruz set last spring. Front tire started showing lumps all the way around the tire at 5 - 6 thousand miles and looked like the plys were seperating. Bought another kenda front tire in early last fall, 'cuz I thought maybe I wasn't diligent enough in watching the pressure. I just replaced that (2nd) front again.....it did the same thing. Had knots all the way around the tire the size of 1/2 dollars and appeared the tire was seperating. This tire, I was very religious at keeping the correct pressure of 40 lbs in it.
The rear tire was kinda ok. It went 14000 miles but started throwing chunks of rubber the size of nickles off in a few places. Had cracks in between the treads too. Even though it was due for change, I feel it should have not thrown rubber chunks. None of my dunflops ever done that, even running almost bald. This last week, I put on a set of bridgestone 701 and 702 exedras to see how they are.
In a nut shell........ In 14000 miles I went thru 2 front tires and 1 rear. Very poor performance. Will never buy Kendas again.
