OK,
Following on from interstate to SE conversion I believe the way to go is to take the wiring from the LCD back to the radio. This poses another problem.
On thefront undersideof the radio (where connections are made) are 4 separate blocks for plugging in various parts of the loom.
The main one has been connected. To the right of this are 2 4 terminal blocks then a further 6 terminal block (this collection may well be for one 14 pin connector). Above this is a further 6 wire block which has a block plugged in (predominantly green & blue wires).
On the instrument panel there are 2 blocks of wires. One black and one white. The white one has been pretty much fully connected during the hashed rewire. The black block has only the yellow/black and brown/white connected so I'm assuming this is the one I need to be concentrating on.
Haynes', in their infinite wisdom, diagram is about as useful (and relevant) as petrol in a C5 (OK maybe a wrong choice of vehicle chosen).
Is there anybody out there who can help either with a proper wiring diagram or with assistance on the best way to link the radio/LCD
Thanks All
Steve
OK,
Thanks All
Steve
