1 - 11 of 11 Posts
I have seen a couple of post here and on another board about Dodge Neon and Eagle Eclipse coil packs on GL1100's and GL1200's
But I have not seen anything definitive.
I have a GL1200 LE (Fuel Injection)
Has anyone had any success?
Thanks!
Ronnie
Yes it has been done on a 1200 I know of but not an FI model but it should not matter, same ignition coils as carbed.
Itinerant Wing Preacher
Worked like gangbusters on my 1100. I had to lower the idle after I installed the neon coil. Jay
Cool, so should be a safe install? Just plug in as original is?
I am installing New wires, New NGK Resistors and Iridium plugs when I change out the coil pack. Current one is bad anyway.
Not sure if you are buying a new set of coils but if you search ebay for neon coils such as this one, you will see that they are about $30 for a new after market. I used a set from a junkyard and they were about $20. Still working fine. If I could have waited I would have paid an extra $10. Just my $.02
BTW mine were for an 1100.
Was planning on new, not a big $ difference as you said.
Used may have a few years left or may have a few weeks left.
Any info on how to switch from the bike plug to the 3 contacts on the new coil?
And how will I know where to plug in each cylinder on the new coil?
The wiring color scheme is the same on 1200s, yellow to the front cylinders and blue to the rear, black/yellow to the center wire.
1 - 11 of 11 Posts
