1 - 17 of 17 Posts
Village Whack Job...
Any one know if an automotive ABS pump can be wired to run continuously.
Don't all electric fuel pumps run continuously?
Other than initial start up, they may be only energized for a couple of seconds. Once an engine is running, the pressure switch keeps the pump operational at all times.
The electrical pumps have a paddle wheel or impeller type pump which are basically designed to run continuously to deliver up a max pressure by being self regulating. The other type of electrical pump is external and they are a vibrating/pulsing magnet.
Why?
Why?
Not fuel pump an ABS pump...it pumps brake fluid.
Sure, they can be ran continuously. Depends on the type as to how much trouble it would be. Most are built into the ABS unit and won't pump anything unless the appropriate solenoid in the unit is powered too. There are some like the early type Hondas that have the pump separate from the modulator.
Might be pushing your luck to run one continuously, I doubt the pump is designed for a 100% duty cycle. Heating may be a problem and pump life would undoubtedly be shortened.
Discussion Starter #10
For the application I have in mind the pump would only have to run for a few minutes at a time.
02 GL1800 w/Auto Pilot
I don't think that brake fluid is going to hurt a fuel pump, but it might. The rubber parts in the fuel pumps might not like the brake fluid, that stuff is corrosive.
The ABS pump motor is designed to deliver a lot of power and fast. It probably will get hot if left on continuously. You might want to monitor the pump's temperature and see how it does.
If you would let us know what you have in mind someone might have an idea of how to do it. I am guessing you are going to make a pressure bleeder. If so an ABS pump is way too much pressure.
if you are going to use it for bleeding brakes, I use a small medical suction pump I found at Goodwill, I have 2 different catch bottles, one for DOT automotive brake fluid, one for 5606 aircraft hydraulic oil.
Monkey with a Football
My guess is that he's going to use it as a "windshield washer" for the car behind him. ;)
That is a great idea.:cool: I may have to look furtherinto that myself.:(
Discussion Starter #16
Brake bleeder was what I had in mind, but the windshield washer thing is tempting.
Guru
I use air pressure at work if Im doin brake work on the wheeled equiptment. i have spare master cylinder caps with air fittings & I regulate down to 30 psi & crack the bleaders one at a time. It works well & I dont have to touch the brake pedal.
1 - 17 of 17 Posts
