I am sure someone on here can tell me if there is a 12 volt power supply under the left front pocket. Its where the aux input wire is located. I am installing a 12 volt power supply to charge my mp3 player and wasn't sure if there is already a power source close to this location or if I need to run wires back under the seat. This is on a 2007 GL1800 premium audio. Thanks in advance.
Yes it is under there, check the connectors with a meter, the correct one will have battery voltage.
Kit
Life Time Premium Member
And decide and find the one you want. If you want power only when the bike is on or all the time.
Found it. Got it hooked up. Thanks for your help.
I have a 08, also placed a sigarette lighter on OEM wiring.
Good to charge the MP3 but not when your driving. Ipod has annoying interferance noise from the enigine.
Installed DENSION Gateway on original CD cabling to my IPOD, no more problems anymore!
Mark
