Auxiliary shifter
739 views 5 replies 3 participants last post by  OnaWingAndaPrayer
#1 ·
Will this work on a 2000 Valkyrie? Thanks Dannie
#3 ·
IF you are referring to the "shifter pivot" found at Cyclemax , you may be able to adapt it to the Valkyrie. On the Goldwing it uses one of the engine protector mounting bolts for the pivot to bolt up. I have no Idea if the Valk has a bolt in this same position.
If you check on VRCC I believe there is information on building a similar setup for the Valk.
#6 ·
I have used the shifter pivot on my 1500 Wing. It is a very nice bit of machine work and does indeed take out the slack. As I mentioned I just dont know if it will bolt directly to a Valk. You might be able to craft the mount point if the Valk does not have on in the correct place.
