When accellorating I have no problem, idleing no problem, but when I release the throttle as it slows down there is backfireing, if I pull in the clutch it stops. I have a owners manual but can't find anything on this. Any ideas?
do you have aftermarket exhausts?, your bike may be running 2 rich. its nothing to worry about though...
Any way to fix it? Could the carb's be involved?
I'm pretty sure that bike has air cutoff valves( kind of a misnomer if you ask me) in the carbs like Goldwings do. If they are bad it will cause a too rich condition on decel and a backfire.
if you have aftermarket exhaust a fix would be to buy the jet kit that works with the exhaust system.
